Hi all!
I need to get command line of msiexec from custom action.
Is it possible legally?
Or do you know some workaround for solve this task?
Thanks for replies.
Obtaining command line of msiexec
Eugene82
, Oct 27 2010 07:45
Posted 27 October 2010 - 08:47
What is it you actually want, the command line passed to MSIExec or the command line used by a Custom Action in the MSI?
For the former, I presume you have an EXE which extracts and executes an MSI. If that's the case, you can normally pass arguments to the EXE to get it to generate a Windows Installer log.
For the latter, you'll be limited to what the MSI itself shows you. Some functions will build their own command lines internally, in which case you'll need to ask the vendor for details.
Posted 27 October 2010 - 09:46
thanks for attention!
my custom action should no to have knowledge about any bootstrapper.
and i need to get command line that was used for launch current msiexec.
in log file exists:
MSI © (2C:C8) [16:05:53:341]: Command Line:
REINSTALL=ALL REINSTALLMODE=voums CURRENTDIRECTORY=C:\Documents and Settings\Administrator\Desktop\Server CLIENTUILEVEL=0 CLIENTPROCESSID=1068
and i need string -
in log file exists:
and i need string -
Posted 27 October 2010 - 17:08
Eh?
If there's no bootstrapper, then YOU will have passed the command line!
I suspect what you actually need are the values for the properties REINSTALL and REINSTALLMODE (the others are populated dynamically as the MSI is read).
If so, you can simply use the properties themselves, using the Session object's Property method. An example in VBS would look like this:
CODE |
strReinstallMode = Session.Property("REINSTALLMODE") |
