hi all..
when i run Setup.exe /s or /r /f1(path\setup.iss) it seem to run through the normal install process but the actual file is not getting created in the specified folder or within C:\windows.
what im trying to do is create an answer file for the .msi installation
thanks in advance...
fresko
missing setup.iss
FRESKO
, Nov 03 2009 03:47
Posted 03 November 2009 - 09:22
The .iss answer file concept only works for InstallScript setups, not for MSI setups.
Instead, either set the properties on the command line or create a transform for this purpose. If you don't need to adjust the selection but accept the defaults, you can simply run the setup in silent mode:
msiexe.exe /i your.msi /q
If the msi is packaged inside a setup.exe it will depend on that exe how to set silent mode. For InstallShield this would be:
Setup.exe /s /v"/qn"
Posted 04 November 2009 - 07:35
just to add... i had this problem earlier on and found a cure for this...
if the software is prompting for a reboot after the install.. add this and it should suppress the reboot..
/qn REBOOT=ReallySuppress"
FRESKO
FRESKO
Posted 04 November 2009 - 09:52
| QUOTE (FRESKO @ 2009-11-04 07:35) |
| add this and it should suppress the reboot.. /qn REBOOT=ReallySuppress" |
...provided of course the packager relied on the Windows Installer reboot triggers and didn't use a Custom Action. Like Symantec do. And IBM. And Adobe.
It's good general advice, though.
