Hi all
I am using IS 7 Developer SP4
I am using Pure Basic MSI ( no IS scripts)
Is there any way to modify the CustomActions dyanamically.. that is using Automation Scripts ..
I just read in article that we can count the number of CA present and fetch the names of CA and even change the name of CA dyanamically (i.e through Vb script) and i tested one and it is changing the name of CA
the code i have written here
Set pProject = CreateObject("ISWiAutomation.ISWiProject")
pProject.OpenProject "C:\Documents and Settings\abc\My Documents\MySetups\DyanamicCA\one.ism", True '
sNames = "This project contains the following custom actions:"
iCount = pProject.ISWiCustomActions.Count
For i = 1 to iCount
sNames = pProject.ISWiCustomActions(i).Name
Next
pProject.ISWiCustomActions(7).Name=WScript.Arguments.Item(0)
pProject.SaveProject
pProject.close
Now my question is can we change CA property FileName & CommandLine dynamically. I know we can change Name of CustomeAction and also other properties like ProductCode PackageCode etc using Set oISM = CreateObject("ISWiAutomation.ISWiProject") oISM.ProductName="New Name" etc
The requirement was such that we are dynamically including a .dll and later we have to register it. To register a dll whose name is not known and can only be known during build time when the dll name is passed to vb script which builds the .ism file. The CA has to pick this passed dll value and register it using RunDLL32 "Path of dll\dllname.dll" RegisterPlugin. Now the dllname.dll will change on each build. How to pass this as a parameter to CA??
I think i am extending in this forum ..
if someone understood my requirement, please feel free to clerify if i am not able to put properly
thanks in advance
sarfu
Modify CustomActions Dynamically
sarfu
, Jan 19 2007 11:52
Posted 22 January 2007 - 05:25
Please some body show me the light..
Is it possible to change the filename and Working directory of the CA from outside..i.e. through scripts Automation object
ISWiAutomation.ISWiCustomActions
its urgent...
thanks in advance.
sarfu
its urgent...
thanks in advance.
sarfu
Posted 23 January 2007 - 15:48
I'm not sure if it's possible using iswi automation, but the .ism file format is either XML (if you selected so) or binary, which means the same as a .msi file. In both cases you can modify the information in the ism file directly, either using some XML tool or using Msi automation.
You need to be sure what you're doing of course, don't break the referencial integrity of the MSI database etc.
Posted 24 January 2007 - 05:36
Thanks Stephan..
i am able to do that ....
the code i have used is ( this is for other users also who encounter the same issue)
correct me if i am wrong..
Set oMSI = CreateObject("WindowsInstaller.Installer")
' open ISM file in transacted mode
Set oDB = oMSI.OpenDatabase("Plugin.ism", 1)
Set oView = oDB.OpenView("SELECT * FROM `CustomAction` WHERE `Action`='RPlugin'")
oView.Execute
Set oRec = oView.Fetch
' change field 4, the Value field cFCL is a varible to hold value of Filename and Commandline
vFCL=oRec.StringData(4)
varproductname=WScript.Arguments.Item(2)
newvalb=WScript.Arguments.Item(1)
vFCL=varproductname+"_"+newvalb+"d.dll"
vFCL="[INSTALLDIR]"+vFCL
oRec.StringData(4) = "RunDll32 """+vFCL +""" RegisterPlugin"
MsgBox oRec.StringData(4)
' update the changed record
oView.Modify 2, oRec
' close the view, commit changes, clean up
oView.Execute
