Hello,
I am using the command-line version of Orca to merge a merge module into an MSI database.
Is there any way to get information about the success of the merge process, apart from analyzing the log file?
I tried to get an ExitCode from Orca, but this seems to be always 0.
Any ideas?
Orca exit codes?
Matthias1967
, May 28 2009 12:31
Posted 28 May 2009 - 13:17
If you're always getting zero, the inevitable conclusion is no, you can't.
Have you explored building a script and using the WindowsInstaller.Installer object? I have a whole collection of scripts (as does the WI SDK) but none of them deals with MMs, I'm afraid. Grab the SDK, have a look at the sample scripts and use those in conjunction with MSDN.
Posted 02 June 2009 - 10:14
I may try using the Merge object; however I have found Orca easier so far.
