I am using Windows installer 2.0, and I have in the installation 4 features. I disabled some of the menu options of all features by giving them attributes value of "8" in the feature table. so the only available options for the features are "installed on a local drive", and "this feature will not be available".
problem is that for some reason, after running the installation, the feature state changes to be "this feature will be installed when required" even thought this option is not being even displayed as an option to select. why is it happening?, how can I avoid this?. how can I disable this option?.
I'll be grateful I anyone can help me on this.
Thanks.
why does the Feature state changes?
TAL
, Apr 18 2002 08:40
Posted 08 May 2002 - 17:37
I have the same problem, I posted a new topic "Advertise feature" right now, because I didn't see your at first. Did you find any solution of this problem or any respond?
Irina Shirinsky
Software Engineer, Heroix Corporation
http://www.heroix.com
Posted 10 May 2002 - 15:40
Hi TAL,
Yes, you were right, it's impossible to add a new component to the existing feature and use it for the minor upgrading.
Irina Shirinsky
