I currently have Developer 8 sp2 on my dev machine and Standalone Build 8 SP 2 on a build machine.
I have a project which builds fine with the IDE or IsCmdBld.exe on the dev system but when I try and build the same project with IsSaBld.exe on the build machine it falls over with error -6645 trying to load a .NET dll
According to Q108597 this is a known problem if 3 conditions are met:
The .DLL was built for .NET. - Yes
The ".NET Scan at Build" property for the component that contains the .NET assembly is set to "Dependencies and Properties". - Yes
The .NET assembly is located on a network drive. - NO! The dll is in on the same hard disk as everything else.
Is this a quirk of IsSaBld ?? I seem to be pretty much stuffed into having to buy a full developer licence just for command line builds on the build system if it is...
Cheers
Ant
Error -6645 when building standalone
Anthony Hughes
, Oct 22 2004 12:29
