iscmdbld -p proj.ism -r cdbuild -b d:\build
However, I get the errors:
Error -1015: Not enough space to fit setup files on Disk 1
Error 53: Invalid custom action type
According the the help file page "Troubleshooting Build Errors," these errors are detailed as follows:
53 Invalid path
The build requires files that are stored in the InstallShield folder under the Common Files folder. Please make sure this folder is in your system Path.
-1015 Unable to copy redistributable file
One or more files may be missing or corrupted. Check to make sure Setup.ini exists in C:\Program Files\InstallShield\Professional - Windows Installer Edition\System\Support; and that Setup.exe, InstMsiA.exe, and InstMsiW.exe exist in the C:\Program Files\InstallShield\Professional - Windows Installer Edition\System\Redist\i386 folder. Reinstall if necessary. Make sure there is enough free space in and that you have access rights to the release location.
Could you please share any ideas as to why this happens? That command worked fine in v1.52 but not with 2.03. Thanks in advance!
