1. is there a way to hide fields on a custom dialog box from the IS script? like setting the VISIBLE property to false? that would be the easiest solution.
2. when i create the custom dialog box, it ignores the transparencies of the controls on the form. so i have all of the checkboxes on there with grey backgrounds set against the white background of the form. i use VC++ to edit my dialog boxes and i have checked (and rechecked a million times) that the transparency property is set correctly there. however, it does NOT carry forward when using it in IS. in fact, if i make an EXACT copy of the resource (form 12032) and rename it to form 103, it still does not save its transparency settings. IS must be doing something behind the scenes to that named dialog. can i reproduce that in my code? any thoughts?
(Edited by surfer5 at 12:58 pm on Dec. 19, 2001)
