I have run across a weird problem with an MSI installer that is very hard to track down, so I wanted to share the experiences somewhere. Scenario is this:
1. Installer Installs Files
2. Installer Registers Files.
3. IScript makes a call to a custom DLL (USEDLL), (UnUseDLL)
4. Installer Binds all installed files, including custom DLL
5. IScript makes a further call to Custom DLL (USEDLL)
Inside Custom DLL, a call is being made to LoadLibrary (DLL2)
Inside LoadLibrary(DLL2), a dependent DLL3 is pulled in.
OS tries to run some init code to initialize DLL3, but encounters an access violation
LoadLibrary fails (return NULL), error code GetLastError() =998
Custom call fails.
This happens only in the RELEASE mode, not in Debug, and only with VC .NET2003 on XP SP1
Disabling the Bind Step resolves the problem completely.
Here's what I suspect is happening - since the BindImage changes the DLL, portions of the DLL may still live in the paging file. Since the timestamp is not altered by BindImage, the page file and the disk and memory no longer agree, hence weird failure when initializing the DLL.
If anyone knows about this problem or about the exact cause, pls give me short email.
Friedrich
BindImage custom DLL's, LoadLibrary fail w 998
brunzefb
, Dec 11 2003 23:30
