After running an application (the program was installed and worked for a long time), the setup procedure was started, asking to enter the setup CD.
Once it was inserted some files were apparently copied, and at the end the setup asked to reboot the PC.
Is it a normal behavior??
Starting of setup procedure
gloom
, Oct 14 2004 09:40
Posted 14 October 2004 - 11:42
I found the article:
"Windows Installer launches unexpectedly, for no obvious reason"
http://www.installsi...ifaq/a/1037.htm
"What you see is the auto-repair feature of Windows Installer. When an application is launched, Windows Installer performs a health check in order to restore files or registry entries that may have been deleted..." and so on.
