Using InstallShield Developer 7.
On one of my installs it is not removing the previous version of the install when a Major Upgrade is applied.
The Upgrade Code remains the same. I change the Product and Package Codes each build, so it should detect the previous installation, remove it, and install the new build. It's not. As a result, I'm getting multiple entries in Add/Remove programs for the same install.
Ideas?
Major Upgrade Not Removing Previous Install
baagan
, Dec 04 2004 01:19
Posted 06 December 2004 - 19:16
There is a known bug, see http://support.insta...ticleid=Q107649
According to http://support.insta...ticleid=Q106467 it was NOT fixed in 7.04 and 8.02
Posted 10 December 2004 - 02:22
Turns out that it was an incorrect value in the MSI upgrade table. I changed it through the Direct Editor and all is well. I wasn't aware that changing the value in General Information-->Product Properties wouldn't change it there as well.
