I have a problem with my Update \ Upgrade install, all my file groups Overwrite property are on
NEWERDATE mode so only newer files are being installed on a previous version,
but sometimes the files on the PC are newer than the one in the Setup
( for example when updating ini files on the PC manually )
in this case the setup will not update these ini files because the one in the Setup isn't newer.
So I want to add an option so the user can decide if he wants to update all the ini files.
I believe that I will need to change the Overwrite property of the filesgroup at run time, Is that possible ?
Does any one has a better idea ?
Elad.
