I'd like to create a log file and put it at the disk image's path. I don't know if there is a way to get the path?
Example: my disk image's WANPatch.exe and has been put at D:\ABC\XYZ
Please help me.
How can I get disk image's path?
TheDong
, Feb 07 2006 03:15
Posted 07 February 2006 - 03:30
If I'm understanding your example, then I would try the system variable SRCDIR.
Posted 07 February 2006 - 05:52
Thanks Taco Bell,
When I execute WINPatch.exe, IntallShield will decompress it into files such as: Setup.exe, setup.iss, data1.cab, ... and move them to C:\Documents and Settings\Administrator\Local Settings\Temp\pft23.tmp\Disk1 and SCRDIR contains the path instead of WINPatch.exe's path. Is it possible to get WINPatch.exe's path?
Posted 07 February 2006 - 14:42
Yeah, I was afraid of that happening, but was hoping we'd be able to get around it based on your original description.
In that case though, I don't know how to get that true source location of the disk image short of doing a search on the whole file system -or- having you abandon a single-disk image for packaging your setup. There's also the possible problem of that source location not being writable.
Therefore, my suggestion is you use an alternative location such as the system variable WINDIR or the supporting uninstall directory of PROGRAMFILES\InstallShield Installation Information\PRODUCT_GUID.
Posted 07 February 2006 - 19:03
I think that system variable PACKAGE_LOCATION would be what you need. However that was introduced in version 10 or so, so it's not available in old Pro 6 (if I recall correctly)
Posted 08 February 2006 - 00:28
Yeah, unfortunately there's no such concept in this version Stefan, but glad to see that IS addressed that shortcoming with their future versions.
Thereore, I'll also see about adding this to the FAQ since it's such a popular question.
Edited by Taco Bell, 08 February 2006 - 00:47.
