Hi
I am VS setup and deployment project,How can i set the default value of Registry key. I want to set the following Key
HKEY_CLASSES_ROOT
CLSID
{Your Band Object's CLSID GUID}
(Default) = Menu Text String
by adding (Default) in Registry option of Setup jsut adds a Key of Same name rather than updating existing one
Help me plz
setting Default registery Value
kadnan
, Nov 27 2004 21:53
Posted 28 November 2004 - 23:01
As documented about the Name column in MSI Help:
| This column contains the registry value name (localizable). If this is Null, then the data entered into the Value column are written to the default registry key. |
In this case "null" means: leave the field empty.
