I am using Install Shield Basic MSI Project.
I have created one xml file and reading values from it and storing in a property named "NAME" using system search mechanism.
I also have to get the computer name which i am getting via registry entry using system search mechanism and storing this is property named "COMPUTERNAME".
Now during installation in customer Information dialog i want to store this two property in COMPANY EDIT edit box.
as NAME-COMPUTERNAME.
Please let me know how can i get to the solution.
Any help will be appriciated.
Abhijeet
How to Add two Different Property into Third Prope
abhijeetkusre
, Apr 24 2011 05:05
Posted 27 April 2011 - 14:11
First of all, you may not have to search the registry for the computer name, but instead use the predefined property ComputerName.
To answer your actual question:
Add a custom action type 51 "set a property":
Property to set: COMPANY
Value: [NAME]-[COMPUTERNAME]
This will combine the values of NAME and COMPUTERNAME (with a dash in between) and store the result in the COMPANY property which you are using in the edit box.
Posted 05 May 2011 - 13:40
| QUOTE (Stefan Krueger @ 2011-04-27 14:11) |
| First of all, you may not have to search the registry for the computer name, but instead use the predefined property ComputerName. To answer your actual question: Add a custom action type 51 "set a property": Property to set: COMPANY Value: [NAME]-[COMPUTERNAME] This will combine the values of NAME and COMPUTERNAME (with a dash in between) and store the result in the COMPANY property which you are using in the edit box. |
Thanks Brother.
it was great help
sorry for late reply.
it worked fine
