Dear All,
I would like to know what is the advantage of transforms(mst) over msi file.
Prathap
Advantages of Transforms(mst) over msi file
reddy611
, Oct 04 2007 07:57
Posted 05 October 2007 - 12:49
You can keep your modifications in a mst file separate from the msi file. For instance, you can have one base msi and multiple language transforms.
Posted 06 October 2007 - 06:03
MST files are heavily used in corporate deployment scenarios to customize the original MSI to comply with corporate standards without modifying the vendor MSI itself.
Posted 08 October 2007 - 11:32
Every time you build your setup, your changes are lost and you need to do all changes again. Actually it's an error-prone extra step.
The changes need to be saved as a MSI Transform file (.mst), So that they can be easily re-applied to any subsequent MSI's.
Edited by swati.agrawal, 08 October 2007 - 11:39.
Regards...
~Swati Agrawal
~Swati Agrawal
