If anyone has any experience with attempting to use a mapped network drive or UNC Path as the recipient of any installed package which uses at least one self-registered dll , then I'd appreciate any input as to how you avoided getting the message dealing with type library failing to register for said components.
Does anyone know offhand if advanced settings or extract at build has these same problems?
Note well that I can register these manually with out any problems (by running regsvr32.exe associated by "double-clicking" on the dll) across the UNC and the ampped share.
This is quite perplexing, since it works w/o WI I am starting to think maybe it is a bug.
Whew, that was one long sentence ;)
Thanks!
