There is a requirement to run the SQL Scripts that has DDL, DML, Proc, Triggers in the SQL Server and Oracle. I found that IS10 provides option to connect the SQL Server only using the SQL Servers View.
Is there any way to run the SQL Scripts in the Oracle database using the IS10.0? Is it supported by IS10.0? Is the IS11.5 only supports the Oracle?
Oracle Support
vijijs
, Dec 07 2005 14:31
Posted 08 December 2005 - 21:46
If I recall correctly:
Support for MS SQL Server was added in version 10.
MySQL was added in 10.5.
Oracle was added in 11.
