I have a basic MSI Project, with IS Developer 8, and I got a Setup.exe, that works fine. The only thing I'm not happy with is that when I right click the Setup.exe, on the Version tab of the file properties, I have something like 8.0.159.1, even though the product version is 1.0. Is there any way to change Setup.exe version number?
Thank you for your help.
Setup version
irinaca
, Nov 05 2002 22:09
Posted 05 November 2002 - 22:54
OK, forget about it, I'm done with that - it's InstallShield version, I guess I cannot change.
Posted 06 November 2002 - 11:53
There should be a setting "Use my version info" in the build wizard.
Posted 06 November 2002 - 20:16
You are right, it should be - but it's not :-)
This still makes me (and my tester!
unhappy. I appreciate your help.
Posted 06 November 2002 - 22:38
You're right. That setting only exists if you use PackageForTheWeb to build your self extracting exe.
