Hello, I am using InstallShield 6.3. I have read a version number from the registry and it is 2.1.3. I want to make a condition that will make sure version 2.1.3 or higher is installed. This will include such variations like 2.1.4 and 2.2.0
Can someone please lend me some insite?
Thanks in advance!
~Chris
Help Evaluating a build version
newport
, Dec 05 2002 17:43
Posted 05 December 2002 - 19:21
You can use the built-in IS function called VerCompare. See the IS help file for more information.
Posted 05 December 2002 - 20:04
This is the code I use to check previous versions of our install and to make sure my Patch is going to run only on previous versions. Note: I use a list because there could be multiple patches. You probably won't need to do that and can use a string constant
HTH
| Code Sample |
| // Check Previous version to make sure we are installing a higher version listResults = ListCreate(STRINGLIST); RegDBQueryKey("SOFTWARE\\Our Company\\Our Product",REGDB_KEYS,listResults); nCount = ListCount(listResults); NumToStr(sCount,nCount); nLast = nCount -1; ListSetIndex(listResults, nLast); ListCurrentString(listResults,sLastInstall); sCurrentInstall = @Product_Version; nResult = StrCompare(sLastInstall, sCurrentInstall); //results from StrComp: below zero A less than B; zero - equal; // over zero - A greater than B if (nResult > 0) then MessageBox(szMsg6 + szMsg7, INFORMATION); abort; endif; ListDestroy(listResults); |
HTH
