COM+ Object construction string
Posted 01 February 2002 - 20:27
Posted 04 February 2002 - 16:07
Can you be more specific as to what you need to do? I have created installations for COM+ applications in the past but am unfamiliar with the term "Object construction string".
Kurt Schneider
Posted 05 February 2002 - 22:35
I have a number of dlls that have to be installed, either as COM+ applications or MTS packages, depending on OS. I also need to set properties for them, such as Security settings and RunAs identity. Can you recommend any utilities/scripts for this (using IS7.02)?
Thanks!
Mike
Posted 06 February 2002 - 18:49
I had a similar situation a while back. I ended up doing the following. I set up my install to put the MTS/COM+ dll's where they needed to go. Then I wrote a Custom Action in VBScript. One the utilized the COMSVCS.dll and the MTSAdmin.dll to handle installing components, exporting packages, setting up security etc.
Stick an Email address in your profile. I'll send you a rather large .vbs file for you to examine. It might give you some ideas. I'll zip it up for ya and save it as txt.
Good Luck
Kurt Schneider
Posted 06 February 2002 - 19:55
I appreciate the help. Email address should now show (if I did it right).
Posted 06 February 2002 - 23:43
Posted 07 February 2002 - 14:54
Posted 07 February 2002 - 23:24
