I have got an annoying problem concerning Windows Installer setups:
On deinstallation the installer needs the original MSI file - means: the MSI used for installation from exactly the same location. This is a nasty thing: If you use an installation image from network and the image has been removed you can not deinstall the installed application - the installer asks for the original MSI and if you can't find it you can not continue deinstallation...
There must be a way to avoid this behaviour, isn't there? Doesn't the installer cache the MSI on installation or something?
Hope, someone has a good solution becaus this behaviour is extremely disturbing for our customers...
Regards,
ReneMT
PS: I've got the problems when using ISWI 1.52 and WiX...
Edited by rene_mt, 02 December 2004 - 09:46.
