I wanted to detect whether the setup is being run from Add/Remove programs or not.
I have found the following code snippet but it is not working. The ADDREMOVE system variable is never set to true.
I am using DevStudio 9 and the project type is InstallScript MSI.
Discussion
For InstallShield X, DevStudio 9.x and Professional 7.x users
The InstallScript system variable ADDREMOVE can be used to detect whether the setup is being run from the Add/Remove Programs or not. For example, in your OnMaintUIBefore event code you can add the following code to detect if the setup is being run from Add/Remove Programs:
if (!ADDREMOVE) then
// Setup is not being run from Add/Remove Programs
else
// Setup is being run from Add/Remove Programs
endif;
Thanks in Advance.
phoenix
, Sep 21 2004 08:23
Posted 21 September 2004 - 11:39
ADDREMOVE applies only to InstalLScript projects, not to Basic MSI or Installcript MSI projects
Posted 21 September 2004 - 11:43
so is there a way by which this can be done in InstallScript MSI project?
