Hi all,
In my script, I will seek on diskette (a:) if the file license is there.
If it is there, I copy this file in the installation directory (directory previously chosen by the user).
However my problem is that my script copies my file in the folder containing the installor (Setup.exe) ><
Here the part of code which copies my file:
File copied at the bad place
P-Y Orban
, Aug 09 2007 08:53
Posted 09 August 2007 - 08:53
// Copier le fichier tee_pso.lic CopyPasswordFile: bPasswdInstall = FALSE; retBox = AskYesNo("Do you want to install the license file ?", YES); if (retBox) then szSrcDir = SRCDIR; strResult = "A:"; if (GetSystemInfo(DRIVE, nvResult, strResult)=0) then if (nvResult=IS_REMOVABLE) then szMsg = "Put the 'Password' floppy disk in drive A:\n and click on the 'Ok' button"; MessageBox(szMsg, INFORMATION); TARGETDIR = svMainDirectory; SRCDIR = "A:"; // Chercher le 'ComputerName' RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE); szRegKey = "SYSTEM\CurrentControlSet\Control\ComputerName\ComputerName"; szName = "ComputerName"; RegDBGetKeyValueEx(szRegKey, szName, nvType, svValue, nvSize); // Construire le nom du fichier de licence passwordfilename = "tee_pso_" + svValue + ".lic"; fullpasswordfilename = SRCDIR ^ passwordfilename; #ifdef DEBUG szMsg = "Fichier de licence recherché : " + passwordfilename + "\n\n"; MessageBox(szMsg, INFORMATION); #endif if (GetFileInfo(fullpasswordfilename, FILE_SIZE, nvResult, szResult)<0) then szMsg = "Can't find '" + passwordfilename + "' on floppy disk\n\n"; szMsg = szMsg + " -> You will have to copy it manually\n\n"; MessageBox(szMsg, WARNING); goto DisplayEndMessage; else // svLicenseDirectory = "C:\Program Files\TEE_PSO\Flexlm\tee_pso.lic"; retBox = CopyFile(passwordfilename, "tee_pso.lic"); if (retBox<0) then szMsg = "Unable to copy '" + fullpasswordfilename + "' to " + TARGETDIR; #ifdef DEBUG NumToStr(szTemp, retBox); szMsg = szMsg + " Code d'erreur " + szTemp + " \n\n"; #endif MessageBox(szMsg, SEVERE); abort; endif; bPasswdInstall = TRUE; endif; endif; endif; SRCDIR = szSrcDir; endif; DisplayEndMessage: // If shared files could not be installed, then users must restart system. if (BATCH_INSTALL) then szMsg = "Some files could not be installed because they are " + "currently in use by other programs in the system. " + "To allow for proper operation of the new program you should restart" + "your system at this time."; CommitSharedFiles(0); RebootDialog("Restart Windows", szMsg, SYS_BOOTMACHINE); else szMsg = "Setup is complete.\n\n\n"; // Message pour Windows NT if (!bPasswdInstall) then svMainDirectory = TARGETDIR; szMsg = szMsg + "Don't forget to copy the license file tee_pso.lic\n"; szMsg = szMsg + " to the FLEXlm directory '" + svMainDirectory + "'\n\n"; endif; endif; MessageBeep(0); MessageBox(szMsg, INFORMATION); |
Thank's for your answers !
Posted 09 August 2007 - 19:46
Try with INSTALLDIR instead of TARGETDIR. If that doesn't help, try setting it immediately before your CopyFile call. And display its value in a MessageBox. If that still doesn't help try specifying the full path in the second parameter to CopyFile.
