I have a CA that needs to execute during a patch as well as the initial install. Right now it's located at the very in of the Execute sequence with property value conditions that do not change during a patch.
I don't know why this CA is not executing during a patch. Is there a special property or type I need to set?
Thanks in advance!
-Scott
Custom Action won't run during Patch
Scott_Epp
, Aug 18 2003 21:20
Posted 19 August 2003 - 15:45
How and where do you set these properties? Generate a log file to see the real values.
Posted 19 August 2003 - 19:29
Thanks for the tip. It appears the values I thought were there weren't there after all.
