I've had no previous exposure to Complus applications and so now only have the basic info but I think that what I want to do is:
(1) Create a Complus Application (WITH SPECIFIC USERID/PASSWORD). UserId/password if requires manual prompting must not be lost between uninstall/reinstall (that is as a worst case, it is entered ONCE per machine only). Also I'm not too sure about hard coding userid/password in MSI (or VBS) in any case.
(2) Install files (dll & type lib), set up server components, add to application.
(3) Set up client components (proxy) (add to application??)
There is little info in MSI.CHM and none that I could find in the Wise References.
While I don't wish to use the "export" option to create the MSI/Cab files, I have looked at the generated output and on install discovered that it does not install the application with the correct userid/password, but simply as "interactive user".
I use Wise Installer and am happy to edit tables directly (as long as I know what I'm doing and why).
Eventually I wish to do all the work automatically, but I can't even attempt this is if I can't do this manually!
Can anyone give me a clue how it works or can email me an example etc (if so zip it please to evade email filter)?
Dennis
db0@anz.com
