I've added a button to the SdWelcome. I copied the 'Next' button and pasted it just above it. I would like to know how I can have it launch notepad to view a readme text file when it is clicked. I am using IS 5.5.
adding functionality to a new control
Frankb
, Jun 13 2001 21:12
Posted 13 June 2001 - 21:43
Find the script for the welcome dialog; older versions of IS have the scripts contained in a subdir of IS program dir; if it's not there I found that older version would allow you to, while debugging, step into IS functions and when doing so just copy the welcome dialog script...may have to go back later to get a script; or write your own using IS doc sample.
make a unique resource id or use one not in use on that dialog; (sounds like you done this)
in the welcome dialog script case statement allow for this new resource id (button) and when it is hit, launchappex notepad.exe.
