I would like to be able to detect whether our application is running during an uninstall or upgrade so I can either shutdown the application, or warn the user to close the program before continuing. I have seen many other installations that do this, but InstallShield had no direct support for this issue. I have tried to search this forum for any info and failed to produce any results. This is obviously something that may installation developers are doing and a friend told me that at least one competitor to InstallShield has that functionality built in.
Does anybody have CustomActions, InstallScript, code, suggestions, etc to help me?
Shutdown running application during uninstall
KBrecheisen
, Jul 30 2009 18:40
Posted 31 July 2009 - 00:56
Usually this is done via custom action. It will need to either query the service status (if it exists) or find another way to detect if the process is running.
I don't think Windows Installer provides any of this by default. If by some chance the application you are trying to stop creates a registry key, or file when it starts to run, you could use the AppSearch table to search for this instead of using a custom action.
You might have also seen the "file in use" prompt. This pops up when a files that the mis is trying to overwrite is held in use. This could be what you are after.
Posted 09 August 2009 - 20:37
see my comment in this post:
http://forum.install...showtopic=16942
let me know if you have problems getting it up and running.
~ Morteza
~ Morteza
