My application requires .NET Framework, so I included dotnetfx.exe into installation (Build your release -> .NET Framework Location -> Extract From Setup.exe). This works properly - .NET is installed when it is not present on target machine. But I want also copy the original redsitributable "dotnetfx.exe" into installation directory of my application (my application need this redistributable package "as it is"). Is there possibility to extract dotnetfx.exe during installation using custom action or something else? I don't want to add dotnetfx.exe into Files of my setup because then it will be twice in installation (in setup.exe and in nested MSI file - 2x 20 MB).
How to extract dotnetfx from setup.exe?
musicube
, May 31 2006 12:58
Posted 31 May 2006 - 19:24
Isn't there an option not to include it in setup.exe, but have it separately next to setup.exe?
Posted 01 June 2006 - 23:17
Maybe you can pick it from the TEMP folder then?
