I've inherited and Installshield Suite install project and unfortunately my expertise is mostly with basic MSI.
I've been given the task of streamlining our install process such that it is "One Click". This means the installation process should only need to be launched nothing else. Currently the only decision made by the customer is the install directory. We no longer require the customer pick this as we now lay down to the install directory of one of our existing products.
The suite installs 2 pre-requisites the only relevant one is .Net 4.5.2 and a number of MSIs based on which of our products the customer currently has installed.
So currently the installer launches immediately begins installing and upon completion goes to the InstallationComplete dialog.
The only exception to this rule is if the customer needs to install .Net 4.5.2 but has a previous 4.5 version installed the customer may is being installed the customer may also
The only thing the customer has to do is click finish, but my boss wants that gone as well but still display the status bar. The problem is I cannot figure out how to close the dialog without user intervention.
Any help on how to do this would be great.
