I want to install Intervideo's DVDXPack on Windows 2000.
It "requires" Windows XP, but I am very confident that it would work on 2000, but they artificially imposed the XP requirement.
Can someone help me with this?
Thanks, Kai.
Trick InstallShield Windows Version?
Kai445
, Jul 11 2003 04:20
Posted 12 July 2003 - 06:04
Well this isn't the kind of question we usually answer on here. I therefore must ask why don't you just use an older version of the program?
However, I have two ideas. One is this hack program called "Tweak NT" which supposedly will temporarily adjust the version number of an OS, so you can try Googling your way across that. You could also try modifying the registry directly for this same affect. Not sure of the location though, but someone's gonna try and get back to me on that.
Posted 13 July 2003 - 04:47
K, I'm gonna keep checking back here, and searching the internet.
Tweak NT didnt do it. It only changes between server and pro versions. That would be handy (I have the original NTtune, or whatever, somewhere..).
I'll keep checking back here periodically.
Thanks for your help,
Kai
Kai
Posted 14 July 2003 - 02:29
Yeah, for some reason I often forget about the registry key in question, but here it is along with the specific values that you'll probably need to apply/override in order to fake out that install:
WARNING: Be sure to _backup_ this area before importing these values, so that later on you can properly restore your system back to normal!!!
Of course I haven't tested this, but these should be the main registry entries, so hope it helps.
| Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion] "ProductName"="Microsoft Windows XP" "CurrentVersion"="5.1" "CurrentBuildNumber"="2600" |
Posted 15 July 2003 - 03:27
Thanks for your help, and if you do run across anything in the future, please remember me
I'll keep checking back, and if I figure it out, I'll post it here.
-Kai
Posted 15 July 2003 - 11:09
There is one thing left
Get a decompiler, extract the compiled script from the install package, decompile it and check what the OS check does ...
But this night be very confusing, because the decompiler produces code that is not easy to be read ...
The preferred way would be:
a ) buy Windows XP
b ) get the older DVD Software that runs on Win2k
or even
c ) use Intervideo's support
a ) buy Windows XP
or even
Edited by Perotin, 15 July 2003 - 11:10.
Gruß / regards
Thomas
Thomas
