Hello-
I have an application that is installed with Installshield 12 basic MSI. It utilizes c:\windows\system\MSCOMCTL.OCX and it is installed via Microsoft's merge module Microsoft Windows Common Controls (6.0) mscomctl.msm. I got the latest set of these merge modules from:
http://www.microsoft...&displaylang=en.
My application runs an Excel macro. We're deploying against Office 2003. My application loads the sheet, reads and writes some cells, but when it runs a macro that's a part of the excel sheet, the Windows Installer repair starts.
I get this in the Applications section of the Event Log:
Detection of product '{646EC6EA-5494-4E51-8597-1894D235300C}', feature 'ScicloneICP' failed during request for component '{22056900-C842-11D1-A0DD-00A0C9054277}'
When I run the .vbs utility here:
http://www.installsi...ifaq/a/1037.htm
I find out that component {22056900-C842-11D1-A0DD-00A0C9054277} is MSCOMCTL.OCX and that Office 2003 has two entries against it and that my software has one entry.
{22056900-C842-11D1-A0DD-00A0C9054277} is used by:
Microsoft Office Professional Edition 2003 {90110409-6000-11D3-8CFE-0150048383C9} at C:\WINDOWS\system32\MSCOMCTL.OCX
Microsoft Office Professional Edition 2003 {00000000-0000-0000-0000-000000000000} at C:\WINDOWS\system32\mscomctl.ocx
Caliper Life Sciences Maestro Workstation Software {646EC6EA-5494-4E51-8597-1894D235300C} at C:\WINDOWS\system32\mscomctl.ocx
It appears to me that the component is always present and registered- so for the life of me, I have no idea why the windows installer repair is popping up. Can anyone help with ideas for:
-why is this happening
-if I can't figure out and fix the root cause, is there a way for me to configure my installshield project to not include mscomctl.msm. Installshield doesn't allow me to unselect it- apparently it knows that components in my install use it. I'd be happy to get the component on the machine another way if that's what it takes.
Thanks much! Andy
windows installer repair popping up on mscomctl.oc
LrngToFly
, Dec 17 2007 16:07
Posted 20 December 2007 - 17:36
I guess you can't unselect it because some other module in your project specified it as requirement (module dependency).
It might be a problem with registry entries - HKCR mapping to HKLM and HKCU.
