I am doing a major upgrade created using IS2009. It removes the previous installation files and also the installation is completed successfully. But the Add or remove program entry is not cleared.
Am i missing any setting or any workaround for this problem?
Major upgrade is not removing Add/Remove entry
avsmpn
, Jul 17 2009 10:38
Posted 17 July 2009 - 15:19
This would indicate that the uninstall of the old version is not complete (did you check the log?) Or are you creating cuatom entries there?
Posted 21 July 2009 - 07:50
The installation went into upgrade mode, IS_MAJOR_UPGRADE was set to "Yes" automatically. Also the new files were installed properly. Only the previous files were not removed. In the upgrade entry, i modified the product version field to "Any earlier version". After this change it is uninstalling the previous version.
But what value should i enter in the maximum version field? I need the Major upgrade to happen only from 5.2.0.x to 5.3.0.x.
Posted 22 July 2009 - 17:30
Windows INstaller doesn't care about the fourth field of the ProductVersion, so you should enter 5.2.0 there and set the *inclusive* flag in the advanced settings. Otherwise it would only upgrade versions < 5.2.0 instead of <= 5.2.0 which is what you want.
