I'm invoking a custom action from my installation script using MsiDoAction. I capture the return code and want to proceed based on the value that I get back. The custom action launches an executable and is configured synchronous/check return code. The executable exits with non-zero return codes to indicate specific error conditions. Everything seems to run ok, but when my negative testing forces a non-zero error/return code, I get a pop-up indicating that a Windows Installer 1722 error has occurred to which I have to respond in order to proceed. Once I've done that, my script follows the appropriate path based on the exit code. Is there a way that I can suppress the 1722 message? Thanks alot
Suppress 1722 Messages
charlies
, Jan 06 2004 01:09
Posted 06 January 2004 - 03:52
If you have to process multiple return codes for an executable, I recommend you to have a VBScript or DLL custom action and launch the executable. The CreateProcess API in C++ and Shell objects run method in VBScript allow you to obtain return codes. You can then use MsiProcessMessage() function or the Message method to send a custom error message.
Hope this helps.
Hope this helps.
Edited by Neo, 06 January 2004 - 03:53.
