I'm getting this validation error when i try to compile workspace in IS Dev 7. Can anyone help..... :
ICE 33 Internal Error 09: API Returned : 284
rmadassery77
, Mar 03 2003 13:55
Posted 03 March 2003 - 13:55
Rajiv Madassery
Galway Scripting Center
Digital GlobalSoft Ltd.
(Subsidiary of Hewlett-Packard Company)
Posted 20 March 2003 - 17:03
api errors are described in msdn.
http://msdn.microsof...rary....des.asp
in this special case this error is not defined ...
sometimes the msi itself is scrumbled. to test this I export all tables, take an empty msi (in orca: new) and reimport.
after all this works (the few times I had similar problems)
In this case i'd
1) export registry table with ORCA (-> registry.idt)
2) delete all keys within orca
3) retry validation (there should be no error)
4) part by part merge keys again and validate
-> like this you can find the source for the error.
hope this helps
In this case i'd
hope this helps
