I have a product released a few years ago using Installshield 7.02. It has an Install Condition check on OS which results in the installation aborting on VISTA. Is it possible to override the Install Condition check using command line properties or such like?
Tim.
Override Install Condition
bradfordt
, Dec 28 2006 14:38
Posted 04 January 2007 - 12:45
No, not unless you added some "back door" when you created it. I sometimes use OS conditions like:
VersionNT=500 (etc.) OR IGNORE_OS
Where IGNORE_OS is a proeprty that you can set on the command line to override the condition. But this is not standard, you have to build it in yourself.
