I have a small package I'm using to deploy a configuration file. It basically overwrites a java.policy file for a select number of users in my company to provide a security workaround.
Eventually, I'd like to remove this package from their machines once the infrastructure is amended so the workaround is no longer necessary.
In this MSI, I've setup another component with the original policy file. I've set a condition on this component as Remove="All", hoping that when I uninstall the package, it will restore the original file.
Unfortunately, this does not work. The package only removes the one file that it installed, but nothing happens with the other component, also from what I can see in the log. Should this not be possible? Should I be using a different condition for the component maybe? Thanks.
Installing files on rollback/remove
pt01
, Feb 22 2012 13:59
Posted 23 February 2012 - 10:32
You can't install something during a complete uninstall. If you keep your package installed, you might be able to swap out the config files. However in your case it might be better to restore the old file in a custom action.
