However the versions of the files in question are different as I can clearly see in Explorer via Properties dialog, Details tab. Also, I know that versions are different because I made them different!
When I apply the patch and check versions of patched files (again using Explorer Properties dialog) I see them changed from the original installation.
So, what does cause this warning?
Normally I wouldn't care too much since applying the first patch appears to be successfull and I see patched binaries having new file versions as expected.
However, I am having problems applying patches upon patches (to be discussed in another post) so I guess figuring out this version warning mistery may help.
Thanks!
[EDIT] I can't confirm it right now but the cause may be in modifying only the last (4th) version number which is probably ignored.
Edited by Tonko, 26 April 2008 - 07:24.
