Hi all,
I am having an issue where I should remove only one component from the installation. Can this be done thru some command line options?
Add/Remove programs -> Change -> Modify -> unselect requires to be done manually on every workstation. If it can be done thru commandline, it will be quite easier.
Thanks in advance,
Sailesh
Removing one component thru command line
dsailesh
, May 03 2010 08:22
Posted 03 May 2010 - 09:53
Sorry, not component , but a "Feature". The problem with just removing the files and registries thru some exe is that during upgrade, the installer still thinks that feature is installed on the machine.
Posted 03 May 2010 - 13:48
If you need to uninstall a feature (not remove it from the project):
msiexec.exe /i your.msi REMOVE=FeatureName
or:
msiexec.exe /i {ProductCode} REMOVE=FeatureName
or:
