I know if i have my project created as the default media, the installer will contains setup.exe and a few other files including .inx file, I can use SRCDIR to figure out the path of setup.exe; however, if my project media type is single disk image, all files are zipped into one single exe file (e.g. myinstaller.exe), I tried to use SRCDIR, but it looks like at that the single image installer is unzip into a temp folder on the target machine, the path I got is the temp path on the target machine, not where the single image installer is.
is there anyway that I can find the path of this single image installer?
Frank
get the location of single media installer
gaolifeng2004
, Jul 12 2004 23:34
Posted 13 July 2004 - 01:54
This is for windows installer projects, but it may work for you as well:http://support.insta...ticleid=Q105487
Edited by Glytzhkof, 13 July 2004 - 01:55.
Posted 13 July 2004 - 08:53
I think for InstallScript projects the name of the system variable is PACKAGE_LOCATION. As far as I remember this was introduced with Professional 7, so I don't think there's a way in Professional 6.
