I have an install I would like to compile and have the setup.exe named something else. I thought if I compiled it into a single executable it would be ok, but this just expands and runs the setup.exe which will not work. Does anyone know how to get this setup.exe to be a different name. When I just rename it the install tries to go back to it and finds it is not there so it gives me a browse dialog.
Thanks.
how to compile an install and get a uniqe executab
tycoates
, Aug 24 2002 04:41
Posted 24 August 2002 - 05:03
Not sure that's possible or why it is necessary. From the user's perspective doing so through a single executable media or PackageForTheWeb is sufficient.
Posted 24 August 2002 - 05:15
We have gone to a managed environment with AD and Windows 2000. We now block setup.exe and install.exe and repackage alot of software to use MSI technology, but there are a couple items I would like to just rename the setup.exe to something else instead of do the repackaging.
Posted 25 August 2002 - 20:37
If you're using Win 2000 and AD you may be better off using a Basic MSI project and deploy via .msi file, without any setup.exe.
Posted 26 August 2002 - 16:54
Yes, that's correct. This was just something that has been around for quite awhile and gets called from the logon script. I was just hoping there was some way around it besides converting to MSI. Thanks.
