We have to reproduce our software in a clean environment before we can ship it.
To do that we recompile the whole project on a different machine and use IS from command line to generate the setup. Now we have two general problems:
1. The root path to the project is not the same, but all source paths inside the setups script are absolute paths.
It is possible that the drive letters are not equal. Some components are now in E:\MyRoot\MyFiles instead of in C:\MySpecialRoot\MyFiles.
How can I use relative paths to build a setup on every machine with the same subtree structure?
2. The compilations aborts due to a fatal error because IS wants to overwrite the ISM script every time. (Not possible because the code comes from a source safe system and is write protected).
How can I avoid that?
Does anyone has a solution for that problem?? Any suggestions are welcome.
Command line build problems
SOWI
, Nov 12 2002 16:47
Posted 15 November 2002 - 08:30
I found a workaround for my problem with absolute paths:
You cannot set a path variable to "..\..\MyFiles\MySubDir"
but you can use the internal path variable <ISProjectFolder> to do that.
Path definitions like "<ISProjectFolder>\..\..\MyFiles\MySubDir" are working well and can be used to avoid absolute paths inside the project.
Frank Dering
