I have an MSI installed on a machine, but want to change some of the entries in the msi database e.g. some custom table entries, I can then upgrade the installed installer which will reflect the new changes.
The problem I am running into is when an application needs a new MST applied to a existing install, I currently have to perform an uninstall then reinstall to get the MST to apply. Is there a way to force a new MST to apply during an MSI upgrade, without reinstalling?
I gather that transforms can only be applied as MSIs are being installed. They cannot modify installations once the product has been installed?
Is this the case or is there a workaround for my problem?
Cheers in advance.
Transforms
Christoph
, Apr 04 2007 09:01
Posted 04 April 2007 - 17:58
That's true, you can only apply the transform during first time install. Subsequent maintenance operations will use the same transform. Any modifications need to be in your patch package.
