AFTER installing our (java) application, when i start it (the installed product) and open a File dialog box the default path (the directory that shows up first) is the Windows directory.
i want to change that to c:\Documents and Settings
Please suggest any pointers that would help me do this.
Note: when i open a File dialog box in our application (the version that is not installed via installshield project) the default directory path is c:\Documents and Settings.
Change default directory in File open dialog box
suvidha
, Apr 09 2002 22:49
Posted 10 April 2002 - 17:34
Make sure you set the working directory in the shortcut correctly
