function CAMigrationPassOneInitProgress(hMSI)
// To Do: Declare local variables.
STRING FunctionName;
HWND ObRecordHandle;
NUMBER RetCode, CtTicks;
begin
// To Do: Write script that will be executed when MyFunction is called.
FunctionName = "CAMigrationPassOneInitProgress";
#ifdef DEBUG
MessageBox(FunctionName,INFORMATION);
#endif
CtTicks = SAT_MIGRATION_PASS_ONE_TICKS;
ObRecordHandle = MsiCreateRecord(3);
MsiRecordSetInteger(ObRecordHandle,1,3); // ProgressAddition subclass
MsiRecordSetInteger(ObRecordHandle,2,CtTicks); // Add the ticks to the current progress total
RetCode = MsiProcessMessage(hMSI,INSTALLMESSAGE_PROGRESS,ObRecordHandle);
return ERROR_SUCCESS;
end;
Diese CA wird in der "Ausführen" Sequenz nach "ProcessComponents" sofort ausgeführt.
Danach wird die folgende CA verzögert ausgeführt. Diese CA verrichtet die eigentliche Arbeit.
function CAMigrationMoveDatabase(hMSI)
STRING StFunctionName, StError, StPath, StTBIIInstallationPath;
STRING StProgramPath, StProgramName, StOldInstallationPath;
STRING StParameter, StExecutable, StRetCode, StTBIIInstallationDisk;
STRING StOldInstallationDisk, StDatabaseFolder, StRegKey;
NUMBER RetCode, Type, Size, iTotalTicks, iTickIncrement;
HWND hRec, hProgressRec;
begin
StFunctionName = "CAMigrationMoveDatabase";
#ifdef DEBUG
MessageBox(StFunctionName,INFORMATION);
#endif
iTotalTicks = 100;
hRec = MsiCreateRecord(3);
hProgressRec = MsiCreateRecord(3);
MsiRecordSetString(hRec,1,"MigrationMoveDatabase");
MsiRecordSetString(hRec,2,@SAT_MSG_MIGRATION_MOVE_DATABASE);
MsiRecordSetString(hRec,3,@SAT_MSG_PROGRESS_STEP);
RetCode = MsiProcessMessage(hMSI,INSTALLMESSAGE_ACTIONSTART,hRec);
// Tell the installer to use explicit progress messages.
MsiRecordSetInteger(hRec,1,1);
MsiRecordSetInteger(hRec,2,1);
MsiRecordSetInteger(hRec,3,0);
RetCode = MsiProcessMessage(hMSI,INSTALLMESSAGE_PROGRESS,hRec);
// Specify that an update of the progress bar's position in this
// case means to move it forward by one increment.
iTickIncrement = 1;
MsiRecordSetInteger(hProgressRec,1,2);
MsiRecordSetInteger(hProgressRec,2,iTickIncrement);
MsiRecordSetInteger(hProgressRec,3,0);
// The following loop sets up the record needed by the progress
// messages and tells the installer to send a message to update
// the progress bar.
MsiRecordSetInteger(hRec,2,iTotalTicks);
RetCode = MsiProcessMessage(hMSI,INSTALLMESSAGE_ACTIONDATA,hRec);
RetCode = MsiProcessMessage(hMSI,INSTALLMESSAGE_PROGRESS,hProgressRec);
Code, der Aktionen ausführt
MsiRecordSetInteger(hRec,1,Tick);
Das Problem ist nun, dass sich der Progressbar nicht ändert.
Was mache ich falsch?
Schöne Grüße,
Richard Schuster
VA TECH SAT GmbH & Co
Ruthnergasse 1
A-1210 Wien, Austria
Telefon: (+43/1) 29129 4611
Fax: (+43/1) 29 28 838
e-mail: mailto:schu@sat-automation.com
Internet: http://www.sat-automation.com/
