Is it possible to have an InstallScript CustomAction after the ExecuteAction Action in UI sequence ? It seems to me that when coming from the Execute sequence the ISCleanUpSuccess action shuts down the InstallScript engine and one is unable to start an InstallScript CustomAction after that.
Reason for doing this: I am not allways displaying the SetupCompleteSuccess dialog. If this dialog will not be displayed another action should be executed which writes some informations into a file.
Thank You for Your help
Barbara
InstallScript Custom Action after ExecuteAction
Barbara
, Apr 04 2002 11:44
Posted 04 April 2002 - 11:44
The difference between theory and practice is larger in practice than in the theory.
Posted 03 May 2002 - 10:31
I solved this problem the following way:
The SetupComplete Dialog is only dispalyed if a special condition ist set to TRUE (e.g. DISPLAY = "TRUE")
I add a direct executed customaction after the install finalize action in the execute sequence (this means the setup has completed so far successfully), This custom action has the condition DISPLAY="FALSE" which means, it is only carried out if the SetupComplete dialog will not be displayed.
Barbara
Barbara
