Currently we are working on a project that involves only packaging application (what our client has developed) setups/ installers using InstallShield 12.
Our plan is to perform a unit test to make sure all the "custom functions" and "scripts" that are written in the Installshield project work as required.
· We evaluated Install Shield Collaboration, and decided that it is not the right one since this is not a development project.
· We evaluated Admin Studio, but it looks like a regression testing suite.
· We found the NUnit MSI would be the right tool for our scenario, but we could find enough documentation for this.
What is your recommendations for our requirement (i.e. perform a unit test of all the "custom functions" and "scripts" that are written in the InstallShield project)?
Arshath
Unit testing tool for InstallShield 12
arshathl
, Jun 07 2007 06:01
Posted 07 June 2007 - 10:39
Use ICE validation to check MSI packages. You can use Orca for the validation, but for a command-line solution use Msival2.exe (somewhere in the Platform SDK I believe).
The evaluation works with CUB files, containing standard rules. Microsoft defined about 100 consistency rules. The method is extendable, you can define your own CUB file with rules for in-house validation, certain Custom Actions etc.
Posted 14 June 2007 - 09:52
Hi Zweitze,
Thanks a lot for your suggestion. It really works for us.
Arshath
Arshath
