I have added a checkbox to the CustomSetup dialog to give the user the chance to specify which of 2 alternative versions of a particular component they want. What I would like to do is recognise when the relevant feature is deselected so that the checkbox can be disabled as it is not relevant.
Detecting change in custom setup selection
jonathan2002
, Dec 05 2002 11:38
Posted 09 December 2002 - 02:06
You can get the current feature state of the the feature you would like to query by using:
&(feature-name)=3 (feature set to install)
&(feature-name)<>3 (feature is not set to install)
Posted 09 December 2002 - 10:31
I can do that, but it doesn't update the status straight away. It seems it has to wait for a button to be clicked before the feature selection states are updated and thus the enabled/disabled status of my checkbox can be changed.
What I really need is something analogous to the OnChange events that Windows dialogs have - I need to detect as soon as the selection state has changed, and STRAIGHTAWAY change the state of the checkbox. How can this be done?
The only other idea I have had is to add a "Refresh" button that the user should click themselves after changing a selection, that would reset the appearance. But that is hardly ideal.
Posted 11 December 2002 - 23:14
You must be able to access an installer call/function that will act on a change of feature states as soon as the user changes the state, but I have no idea where to get this from, sorry.
Could you maybe call a windows API call to monitor the feature state?
As a last resort you can use a refresh button which should work fine.
