MY standard 7.02 project works fine on all platforms except 95 (European Languages). It is working fine on US English.
The error messages that I got on Dutch 95 os are:
interne fout 2717. InstallFinalize
and then
fout -1603.
I logged the installation and this is the problem Area:
SelfRegModules: Bestand: msxml3.dll, map: C:\WINDOWS\SYSTEM\
Actie 12:49:50: ISSelfRegisterFiles.
Exception code: C0000005 ACCESS_VIOLATION
Module: C:\WINDOWS\SYSTEM\MFC42.DLL
Function: 0x5f401004
Registers:
EAX:023B8920 EBX:00000000 ECX:023B8920 EDX:81D39A70 ESI:02C3AF20 EDI:023B8920
CS:EIP:0137:5F401004 SS:ESP:013F:02FAF434 EBP:02FAF45C
DS:013F ES:013F FS:248F GS:21C6
Flags:00010212
Call stack:
Address Frame
5F401004 02FAF45C 0x5f401004
-- 0x00000000 0x02C3AF20 0x02C30000 0x02C3AF20
Actie be‰indigd 12:49:50: InstallFinalize. Retourwaarde 7.
Actie 12:49:50: Rollback. Terugdraai-actie:
Rollback: ISSelfRegisterFiles
Any Ideas?
Error 2717 and crash
beSHARP
, Aug 09 2002 01:34
Posted 09 August 2002 - 13:13
this is a Microsoft Foundation Class DLL. i have experienced problems with some of the versions provided by different applciations. you might want to use the GetVers.EXE tool from MS and determine the version of the file on the Win95 and other platforms. check to make sure they are the same. if not maybe try and use the Win98 or a later version.
i know all upgrades of a DLL are supposed to provide full backward compatibility but i have found this not to be the case. i have seen however, that different versions of software ship with this ( and a couple of other common files ) of different versions.
so i am thinking that if you can check the versions and then match to a version that is working on a similiar platform ( 95/95/ME or NT/2K/XP ) you might have some luck.
this error is stated as being "Bad action condition or error calling custom action". my thinking is that your custom action makes use of the MFC file but requires a different version. maybe yes, maybe no ?
the 1603 error is a fatal install failure error code and sometimes indicates that the file is in use. as i said this is a common file and might also be locked by another process...
good luck!
good luck!
Posted 27 August 2002 - 11:52
I had an error like that, too.
In my case the reason was a dependency on msvcrt.dll and/or msvcirt.dll. I had to change the existing versions (V6.0.8797.0 and V6.0.8168.0) against V6.1.8637.0 and everything worked fine.
These newer versions are included in hhupd.exe from MS for example.
h.teichert-ott
