Hello,
I am buldin instllation with Wise for Windows. I am using BDE merge module.
With BDEMMCFG.EXE I generated BDEMERGE.INI witch includes aliases (witch I
need) and other settings. The readme says I am supposed to distribute this
ini file with the msi file. Now, where (in what directory) do I put
bdemerge.ini?
I would be very grateful if you could help me with this question.
Regards,
Marko Strukelj
markos@datalab.si
BDE merge modules and bdemerge.ini
markos
, Sep 05 2002 08:31
Posted 12 April 2005 - 10:43
| QUOTE (zonathen @ 2002-10-15 18:16) |
| You put the .ini file in the same directory as the msi. That's all. |
Is that the same behavior whatever packaging software is in use ? This doesn't seem to work for me... (I'm using ISX 5.0 and I have the configure module menu entry disabled for the BDE... )
Thanks in advance...
Zaffarelli
